Hi Ace,
Relatively new to Kustom. Nice piece of software but I’m having some issues with KWGT I hope you can take a look at.
Firstly, in the latest play store build when I create a widget on my home screen, when the editor loads all I get is a small box which can not be resized. it’s not inheriting the box shape of the widget space it’s intended to occupy.
I’ve seen others have also reported this.
I tried rolling back to an older APK (the previous stable build) from your website, now I can successfully create and place my widget on my home screen, but after every reboot, the widget shows the “tap to setup” prompt, and when I tap, the KWGT app runs through the entire first setup wizard, including reapplying all permissions, ect.
This is being used on an Android 13 AI Box in my car, so keeping the device running at all times is not practical.
Cheers,
Will
