Multiple functions and format in a FOR LOOP
Hello,
I'd like to display stacked multiple consecutive events.
I then use fl(0,9,"i+1", "loop")
In the "loop" i'd like to use for example : "df(EEE hh:mm, ci(start, i)) ci(title, i)"
In addition, I'd like to use different format for df(EEE hh:mm, ci(start, i)) and ci(title, i)
Is it possible?
Thank you for your help ! :-)
Okay my bad... it's possible with a '+' in between each functions...
Format remains a problem, it's not unterstood at all...
Okay.....
I feel dumb.
Using + with BBC code was the solution. Actually this + solves every problem ^^
