Multicolour gradient.
Please add multicolour gradient in color section for all objects, if it's possible of course.
You can create multi color gradients using more than one shape and then rotating the 2nd shape and placing it in a container directly above the 1st shape
I know that solution, I was thinking about the text and font icons
XOR and multiply overlapping shapes
