Moonrise next day
Is it possible to add moonrise/set for next day like with sunrise/set?
Tnx
You can already get the moon rise for the next day using $ai(moonrise, a1d)$ (a1d means "add one day"), there is no "next moonrise" equivalent however like "nsunrise", is that what you were looking for?
Yes, that was what I was looking for. I'll give it a try. Tnx
Frank, can you add it also in the faq pages? (in other words here http://help.kustom.rocks/i160-ai-astronomical-info-sunrise-suset-isday) I was wondering the same and after a while I found this question because the astronomical function page report only Syntax: ai(type). It would be nice to know it for the next users. Thank you.
Added 2 new examples, they will be updated on the page as soon as i build a release
