Maxlines on Oreo added "..."
Update collapsed my calendar events with ellipses. How do I undo that and revert to simply cutting off mid-word by the character limit I set?
Editing the post to add that going into the editor and manually changing maxlines back and forth mostly corrected the issue with 2 exceptions. I'm anticipating a device reset will fix those as well.
Is there a way to delete this post?
Unfortunately this cannot be fixed, its an Oreo change
