Can you make a repeating shape? I feel like I remember making a square for instance and you can choose how many times you want it duplicated, and which direction, and control with the distance between them. I’m trying to make a process bar that is in a few circles but I can’t use the repeating shapes feature in the progress bars because I want it to be able to take up half a circle. Let me know if anything doesn’t make sense
You can add a progress bar and set it to Custom. Change Mode to Repeat Shapes. You change the value of the Section to determine the number of shapes. I believe the default shape is a circle, but you can change this by going to the Style tab >> Shape.
If you want rectangular “arrays” you can also setup a stack group, create an object in there, copy/paste that several times and then set the “padding” in the group
