Load preset into a widget
I’ve designed a preset and now I don’t know how to load it into an empty widget that I was put on the home screen.
It drives me crazy :frowning:
From the empty widget in the editor, open the side menu and select “Load Preset”. If you managed to export the preset you designed, you can find it in the “Library” tab. If not, check if you can find it in the “Backups” tab if it was autosaved.
