Layer with notifications not visible but clickable
I’m a long time user of KLWP on a OnePlus Nord and never experienced issues on this phone. I recently upgraded to a OnePlus Nord 4 but the experience has been pretty horrible thus far. Some of the issues I experiencing with this new phone are related to KLWP.
The most annoying one is that when I receive a notification these arent always visible on my home screen.
So let me explain, I have a layer which holds the notification elements which has the following formula set $if(ni(count)>0,IF_NOT_LOCKED,NEVER)$. This always worked perfectly on my old phone. The issue I’m experiencing now is that sometimes this layer does not show. But the layer is actually there, because I get a vibration when I click the position where the notification should be. It just does not show any of the elements within this layer. When I go into KLWP the editor shows the notification layer just fine though. But even when I save and go back to the home screen the notifications still arent visible.
[EDIT WITH EXTRA INFO]
Sometimes when I keep my phone unlocked for a longer period of time the notifications that have been active but are hidden do show up at some point for no specific reason. It’s as if rendering the layer takes a really long time.
[/EDIT]
What I done so far is exclude KLWP and Nova Launcher from battery optimization. Made sure both app have the proper permissions. That these permissions cant be provoked. So, all the usual.
I also tried to find a pattern where for the cases where it does show the layer to no avail. I’m now to a point where I dont know what to do anymore to make sure the my notifications show on my homescreen, so some help is appreciated.
p.s. due to another issue I’m having the touch action of a notification does not actually open that corresponding app . This also happens in the case that the notification layer is actually visible. But I want to first solve the issue where they arent visible at all.
I would suggest you this code snippet, in replace to your existing one.
if(
  ni(count)>0 & si(locked), ALWAYS, REMOVE
:smiling_face: :+1:
Unfortunately it makes no difference. :frowning:
I have added some extra information in the first post.
