Layer opacity
This feature, if implemented, would apply to overlap groups, stack groups, and komponents, in their "layer" tab.
Much like a "scale" option for layers allows you to resize a whole container instead of resizing its elements, a layer opacity option would allow for overlap groups (or other containers) to change their opacity as a whole, without having to change opacity of every object inside that container.
This effect can currently be faked with a partial fade out animation, but a dedicated solution would be way more reliable and robust.
Thanks for reading :)
Overlap Group in 3.34 will contain opacity and color filters like bitmaps (saturation, brightness and others), stack and komponent wont support this
