I cant launch any shortcuts on my klwp. Only the music button works fine. Somebody can help me? Sorry for bad english
Please enter the editor, press the shortcut from the editor and press "change" so you can modify it and ensure its an app that you have on your device. Then save, go back to your screen and ensure that device vibrates when you click on them, if it does not you might have something on top of KLWP that prevents KLWP to get the touch (like the launcher dock) or maybe your Launcher is not sending the touch actions to Kustom (in Lightning for example it has to be enabled in the settings)
