Launch Shortcut - Gmail Label
Hi. I am a very novice user of this app. I have been able to set up a widget to show my unread gmail per label (thanks to this forum). Now what i would like to do is be able to go directly to those label folders in the gmail app by touching their respective text in the widget i created. I have tried using TOUCH>>Launch Shortcut, select the gmail label icon, then the actual label i want, and tap done. it looks like it saves it, the screen flashes then i get a message "preset loaded". However the touch function does take me to my label and when i look at the TOUCH tab in the layers, it is not saved.
On a side note i was able to create a link to the app in general using TOUCH>>Launch app so i know the touch functionality works. I just want to be able to go directly to those folders.
thanks in advance for any help you can provide.
B
I am also getting this same error. Would love for this to work
