Yoffset & xoffset disapeare and appeare
And the text added previously doesn't have the option of Yoffset & xoffset
Can you confirm you are on latest version? 3.25? Can you send me the preset with the issue?
i am on the latest version of 3.25
and i found the bug will be fixed after changing the default vale from "$df(hh:mm:ss)$" to anything
I tested the bug on my other Nexus 5 device (new setup, android 6.0), the bug is still here
Ok, i might have understood the issue but still not able to reproduce, will try again
