KWLP stopped working today
Hello,
KWLP stopped working this morning after a reboot which is scheduled on a weekly basis.
This is the error message:
Your device (or Rom) lacks live wallpaper support, this app cannot work without it.Please check online on the community how to solve this or install a ROM with Live Paper libraries.
Phone: Samsung 7s edge, android 7.0. Not rooted.
kwlp latet version installed.
That message means that either you or your ROM has Android Live Wallpaper support removed. The live wallpaper support is part of the core Android functions and should not be removed but some ROMs have it stripped. This will prevent any live wallpaper to work this is not a Kustom issue.
Hi Frank,
Thank you for your reply. i found out Package disabler pro was causing the issue/
Eric.
