KWGT. Problem working with MacroDroid
KWGT v.3.78b510015 if there is a shortcut to a macros from a MacroDroid in the widget, the widget simply does not load, the desktop shows the message “Loading…”, after deleting the shortcut, the widget loads successfully
Able to reproduce the issue.
This is fixed in the new beta, many thanks for reporting this, you can find it in the download page:
Any build >= 3.78b510608 will work
Play store being approved
yes, everything is fine now
