KWGT Pro Subscription
So i purchased the pro for this app instead of going through a separate app, however every widget i download asks me to download the separate pro app, can anyone help? Maybe i am doing something wrong.
You can get around this by loading the preset from within the KWGT editor. To do this, go to Load Preset >> Explore >> Installed packs. You can also send an email to [email protected] and see if they can swap out your license with the separate pro key.
Thank you so much for the help!
