KWGT instantly close when I open it
Hi !
Setup:
LineageOS 18.1 unnoficial, I installed microG, Nova Launcher and did unticked battery optimisations.
No Greenify and KWGT comes from official repositories and widgets keeps "loading...".
I checked all my apps and modules on Magisk/EdXposed, I really have just a few and none are concerned into some kind of restrictions.
To me, it might simply be microG since widget's range of actions is pretty wide and might rely in a way or another to some google services ?
I'm pretty sad since all the specs of the app sounds awesome (I come from Zooper widget).
If you have any clue ?
