KWGT I am not able to set the flow parameters
I am tring to create a flow in KWGT.
For triggers, like a cron, it takes the default value and does not allow me to change.
Same with other triggers and also actions.
There is no option to edit after this and I am not able to create the way i need.
KWGT 3.78
Xiaomi Poco F5 Pro.
Have you checked just in case the Flow you want to edit is locked?
