KWGT Flows
I’m using the following Tasker auto tools command in a Touch / Open Link:
Url - autotoolscommand://curprs=:=$wi(press)$
This works. But now I’m trying to get this same thing to work in a Flow / Intent:
Will only work if I am in the editor when the CRON triggers the action. Otherwise nothing seems to happen.
This is probably a good time for the ‘glorious developer’ to become involved :slightly_smiling_face:
I would suggest that you test if this is a trigger issue. Test with manual trigger to check if this is a CRON issue or something else.
Thanks for the suggestion.
I was able to determine that CRON was working properly by adding a set global variable action into the same flow. The global variable was getting updated properly.
I tried it before and after the intent.
