KWGT editor starts with a very small square
When I Create New, the editor shows a very tiny square and I cannot increase its size even if I increase the scale. How do I set it to the correct size?
The size of the canvas in the editor is determined by the size of the Kustom widget that you added to your home screen so make sure to start with a big one before you start editing.
