KWGT does not refresh info
Hello everyone.
For a few days now, my weather forecast widget made with KWGT has not refreshed. It is programmed to do so every hour but only manually responds.
I haven’t modified anything, I haven’t updated anything. The widget is in the list of non-battery optimized apps.
Any suggestions to fix this? Thank you.
Kustom Widget Pro v 3.74b331712
I have finally managed to fix the problem myself: delete cache, delete data, uninstall and install the App again.
In this way, it has returned to its usual behavior, in my case refreshing the weather forecast every hour. Maybe it will help others who come here with the same problem.
