KWCH Next appointment is not displayed
How can I display the next appointment? The appointment is displayed in the editor, but not on the clock. Text with formula or complication does not work either.
Currently calendar data is not supported on Wear, query needs to be done on the phone, I am working on this issue, meanwhile you can try to get similar data from the complications
I was able to get it to show only if I set next event as a complication.
Next appointment is not displayed for me, not even as a complication.
@Billy_Higginbotham with kind of complication do you use, smal or long text?
Sorry for the late response. I used long text
@Billy_Higginbotham
Thank you, that worked
