I dedicated and set up an Android tablet to run only KLWP (yes, I love KLWP that much), and I found that Kustom will not update weather and wg JSONs, if the display is set to Never Sleep, regardless of the update interval. When I turn off the screen and turn it on again, KLWP will immediately auto update.
I should also note that updates work fine on my Android 6.0.1 phone. I only have the problem on 2 identical Kit Kat tablets. Also, manual updating on these tablets works fine.
Hi, I am having this exact issue now in 3.38. I have an old phone that I am using as a google phone hub replacement, and the display is permanently on. I use tasker to extract the current temp from our local weather bureau website every 15 minutes and save that to a text file, and then I have KLWP set up to read the text file using WG.
I have confirmed that tasker is completing the task every 15 mins and updating the text file, however KLWP does not recognise that the text file has changed until I turn the display off and then back on again. Any help or advise much appreciated
