Kustom LWP crash
Steps to reproduce:
- Open KLWP
Crash:
FATAL EXCEPTION: main
Process: org.kustom.wallpaper:editor, PID: 28763
java.lang.RuntimeException: Using WebView from more than one process at once with the same data directory is not supported. https://crbug.com/558377 : Current process org.kustom.wallpaper:editor (pid 28763), lock owner org.kustom.wallpaper (pid 4162)
at org.chromium.android_webview.AwDataDirLock.b(chromium-SystemWebView.apk-default-438910503:27)
at va0.j(chromium-SystemWebView.apk-default-438910503:31)
at ua0.run(chromium-SystemWebView.apk-default-438910503:2)
at android.os.Handler.handleCallback(Handler.java:883)
at android.os.Handler.dispatchMessage(Handler.java:100)
at android.os.Looper.loop(Looper.java:214)
at android.app.ActivityThread.main(ActivityThread.java:7356)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:940)
System Info:
Brand: samsung
Product: j7xelteub
Board: universal7870
Architecture: aarch64
Rooted: true
OS Version: REL 10 (SDK v29)
KLWP version:
3.58b212515aosp
