KLWP Not Rendering Images
I’m running KLWP on my Samsung Galaxy S25 (base model), Android v15, One UI v7 with Nova Launcher. I have tried the latest stable release and the beta, and the issue is present in both.
KLWP is totally unable to render images on my home screen. I’ve seen the other threads about recent image issues and followed all of the advice in them and nothing works.
My image is in the Kustom folder, which is a subfolder in the root of my phone. I specified that folder as KLWP’s main folder using Settings > General Settings > Main Storage.
Whenever I try to select an image for the background of my wallpaper or use add an Image object (statically, no formulas used), the KLWP editor will display the correct image. But when I save the wallpaper and apply it to my home screen, the image does not display correctly. Sometimes it is just blank, as if I hadn’t selected an image at all. Sometimes I get static-like noise in place of the image.
Would appreciate any help or a fix, since this makes KLWP pretty useless for my use case.
In classic fashion, I figure out the problem minutes after posting about it. I checked “disable parallel rendering” and voila, I can see images again.
