KLWP not compatible with Moto 5G?
I just got this new phone, it’s the Moto G 5G model number XT2417-2 with Cricket service and I can’t get KLWP to work as it says “this functionality is not supported by your device” when using smart launcher so I tried the stock launcher and Nova and they all say something similar, basically that live wallpaper is not supported. Is this true??? I can’t believe I’ve had much cheaper phones with wayyyy less features and the app still worked. I’m gonna HATE it if I bought a phone that won’t work with KLWP…
Thanks. B.
KLWP uses the standard Android live wallpaper platform. If your device is using a different one then you may encounter this issue. I suggest you talk to Motorola to confirm this.
I’m an idiot :person_facepalming: the live wallpaper picker wasn’t enabled out of the box I guess so I had to go into settings and enable it. Thanks though!
Awesome! That’s good to hear.
