KLWP displays blank screen despite being set as wallpaper and having content saved
Got an new Zenfone 10 and started to get KLWP setup.
I am not a beginner and was just doing what I do with every new phone.
But despite loading my original preset, setting KLWP as my wallpaper, it just displays a blank screen.
Video here:
https://www.reddit.com/r/kustom/comments/16x2g4e/after_setting_klwp_as_my_wallpaper_and_saving_my/
Notes:
It’s not just an issue with my setup, I tried using the templates but to no avail
It’s not just a setup with my launcher, I switched to a different one and same result.
I already tried the suggestion of disabling parallel rendering and same result.
Can you try installing Nova Launcher just to check if this is a launcher-related issue?
My bad, I should have mentioned.
Nova is one of the launchers I tried it on.
That and Niagara, both behave the same.
update: still not working, but have tried more things:
  • clearing cache
  • uninstalling and re-installing
  • saw i was in the beta program, left, uninstalled, and re-installed
still no luck
update update: did the above, and it didn’t work.
left my phone alone for a minute, and when I came back, it works now.
for future readers, try the above solution if you’re having this issue.
Zenfone 10 on Android 13
