KLWP Available spaces Not working
I am return user of klwp had about 2-3 years ago, but I have question isn’t available spaces in klwp’s navigation menu supposed to be like same as kwgt’s available spaces? was that how available spaces supposed to function? I think there should be feature to that allows to store multiple presets in klwp’s available spaces such as I had theme purchased from google play fortunately dev/ theme creator was able to provide the unlocked klwp file thanks to him for that. but for themes like you find on reddit some are locked, and those theme creators might be reluctant to give unlocked file because people just change some parts of theme and share it without providing theme creator credit. so can we get feature where you can create one or more available spaces and you know have the locked theme loaded in that space, make changes and apply and when you want to apply another theme you can create another one have theme in that and when you want to switch back to that previous theme you can switch to that theme without losing those locked theme changes that you made and of course just for clarification there will only be one theme that is applied but multiple theme spaces from which user can only choose one applied space but can edit/make changes to theme without having it applied. This would really be feature that helps both the creators and users.
In KWGT, available spaces are meant to hold designs you have for individual KWGT widgets in your home screen. Since you can only have one wallpaper at any given time, I don’t think available spaces can be used in KLWP. At least I can’t find a way to use it this way. I could be wrong.
Right now available spaces in KLWP is only useful if you customize the notification at that point you can have multiple spaces (1 wallpaper and 1 notification) till then is not useful BUT this will change at some point in the future since there are quite a few requests to allow editing multiple presets together.
