KLCK unlock screen
Hi,
Is it any chance unlock screen with physical button?
I have Samsung S8 and I use BxAction, so I can remap Bixby button.
Thanks, Bogdan.
Hi Bog, this is not technically possible, if you can do this through a shortcut then theoretically you can associate the shortcut inside the app using a touch action.
Ok. Thanks for answer.
