KLCK not working
When I try to set up a custom lock screen, it does not work. There is no lock screen whatsoever or it opens straight to my home page. I am using a pixel 2 xl with latest android update
You enabled the Lockscreen in the Klck settings.Klck was working previous to your last Android update, see if Klck is not in Battery save mode in your phone settings.
Yes the lock screen was enabled. KLCK is not in battery save mode either.
Any update on this topic? I get exactly the same problem
I have the same problem on p20pro. I turned on in settings, but nothing happens.
