This is what it currently looks like, the picture in the background is what the lockscreen that I set on my phone is, it’s a different photo from the one I set in klck. Is there any way I can get the photo to load properly?
How are you specifying the background?, ie, What do you have in your Background > Bitmap field (file from file picker, formula, global to formula, etc)?
I made a rectangle, then fx>texture>bitmap, I also tried turning the bitmap into a global but it still didn’t work
If you are specifying a file path in a variable, you are probably now suddenly experiencing the same problem I am: Sudden "permission denied" errors on file accesses
