KLCK - "Blurred Background" mask doesn't work
Even when the blur is all the way up, the object isn't affected.
It's work in my Klck preset.You have an image set as background? How are you using it?
It is working now. I had an image set as my background and the object was staying a solid color instead of blurring anything. Don't know why it decided to work, but thanks for the reply!
Good good!!👍👌😀
