it would be great if there would be a formula for handling the soundprofil of the phone... (sound, vibrate, silent) - e.g. to display with an icon the soundprofil
You can do that very easily in conjunction with Tasker - any Task that handles volume profiles can send variables to Klwp to change text/icons/etc.
Hi,
Indeed it is a solution but I already bought Automate, and Tasker is a paid app (then an extra EUR 3 is required)...
Wouldn't it be better that it is natively implemented by KWGT (+ I assume it would be less battery consuming) ?
You want to display or change it on touch? I think both can be done but just to understand
for my setup i just want it to display but changing i think is also appreciated :)
I have successfully done this with KLWP & Macrodroid. I can maybe post if interested.
Hi,
I'd like to get the same functionality. I would be grateful if you could post your solution.
Thank you very much
