Is there in any way i can extract luminance value from a color?
i was wondering if its possible to extract luminance value from example($bp(dominant, mi(cover))$)
Well I guess with some manipulation of the returned color value, breaking it into the individual RGB values using tc functions, converting them from hex to decimal and then from 0-255 range to a 0-1 range using mu functions and some maths and then using this luminance formula:
Luminance L, red R, green G, blue B
L = 0.2126 * R + 0.7152 * G + 0.0722 * B
You could calculate it.
Here it is actually, taking the color #ffeedd as an example:
$0.2126 * mu(h2d, (tc(cut, #ffeedd, 1, 2)))/255 + 0.7152 * mu(h2d, (tc(cut, #ffeedd, 3, 2)))/255 + 0.0722 * mu(h2d, (tc(cut, #ffeedd, 5, 2)))/255$
thanks a lot it worked perfectly kudos man
