Interface showing wrong input fields
Sometimes I can see input fields that shouldn't be active on that moment.
As an example if I set a progress object to split progress and switch from linear to circular in the style field, then the options become available.
Sometimes when I change a padding, the offset fields show up for a split second after changing a padding value (or the other way around).
I can live with this, but I was demonstrating the app to someone and it flipped almost on every screen (he has a sony xperia z). Could it have something to do with high ram usage or something?
