You need to put the JSON path string inside quotes, so like $wg(url, json, ".[?(@id == 'bitcoin')]")$ inside the jsonpath statement also avoid using double quotes, use single ones.
Hi I tried your suggestion but I just can't get any api to work, I get er:null. Can you please help me?
