Importino fonts
, after downloading and importing a font when I search for it in the app it says not available in memory, after clearing the cache and doing a forced shutdown of kwgt the font can be applied. samsung s23 plus android 14 ,kwgt ultimate beta
Can you try to manually move the font files to the “fonts” folder and see if it’ll work that way? Also, test with the latest beta (3.75b406816beta) and see if that will work for you.
once the font has been downloaded, it is certainly moved to the kustom font folder, but once a text has been inserted, going to search for that font, it gives an error saying not available in the internal memory, after a forced restart and cleaning of the cache, the font can be applied, I’m already using the latest beta of kwgt, it’s a bug, Frank knows it and it will be fixed
