I want to be able to say that if the music player is stopped or if the music player is spotify, then make the color green. I can't figure out how to do this. Please help.
So let's say you have a shape and you want to change its color based on the fact that music is stopped or playing, lets make it green if playing and red if not
- Open the Editor and Create a Shape using the "+" on the top right
- Change the Shape aspect according to your needs
- Go in the "Paint" section and select the color preference
- On the top bar the "Formula" icon will appear, select it
- Now the preference has been switched to a "Formula" preference so it's now controlled by an expression rather than a simple value, click the preference to edit the Formula
- Type
$if(mi(state) = PLAYING, #00FF00, #FF0000)$
and press the "ok" button on top right
If you want to change it when player is spotify you can use:
$if(mi(pkg) = com.spotify.music, #00FF00, #FF0000)$
If instead you want it green only when its BOTH playing AND Spotify use
$if(mi(pkg) = com.spotify.music & mi(state) = PLAYING, #00FF00, #FF0000)$
