If into marging of stack group
I have a formula (if with "or") into marging of stack group than is not updates marging size. I must to use a textfield with same expresion to force update the value (Workaround).
Can you provide an example? What formula are you using?
The expression is:
$if(gv(CoutEv)=1 | gv(View_1)!="EVENTS",0,5)$
Where CountEv is a switch and View_1 is a List with 3 String values. Into editor works fine but not into desktop...
