The formula $if(ni(pcount, com.whatsapp)>0, 1)$ doesn't work. The comma after the pcount puts the >0 out of the condition, into the then, which makes the formula useless. Is that a bug or ist the formula wrong?
This is not possible, please ensure you dont have any special chars in your formula, type it again manually if you pasted it from somewhere
Thanks for the fast reply.
Retried it, this time it worked, i dont know what the problem was.
