Icons instead 3 dots menu after selection
I don't seem to find a reason for the 3 dots menu after selecting an item. I mean if we want to copy an item, you just select it and tap the copy icon. If we want to cut, then you need to select, tap the 3 dots menu, select cut option. It would be much easier to have the options from the menu at the top as icons.
Yeah but doing this will make some icons not reachable from small screens, i need to make it smart so it displays them if the screen is wide enough
Good point. So maybe some kind of pop up bar right above the bottom container? You don't need to see the whole preset when doing this operations.
