Icons disappear when I open KWGT
I have a panel I created using KWGT and it worked well on my last phone (Note 9) I moved to a new s23 Ultra and imported the app it worked until I went to edit it with KWGT then all the icons disappear and show only placeholders in the editor. Any idea whats happening?
Please check the following:
  • Nothing is clearing Kustom cache automatically
  • You have not deleted the original preset your imported (so if you import a widget then delete the widget you imported this will happen)
  • Kustom is removed from battery optimization and has storage access
  • You are on latest (3.73 as we speak)
