I can not import a predefined widget
I am trying to import a predefined widget (wich works on another device), but I receive the error described in attached file.
Al ready purge the kuston folder and delete all data from app, but the issue continues.
I am on AOSp CRDroid rom
Thanks in advance for the help
Regards
There is an issue with rooted devices up to 3.73, this issue seems to be fixed in 3.74, you can download it only via manual download here:
Let me know if that fixes your issue
