You must be running an older version. Check and make sure that you have 3.77b435216 installed.
Im experiencing this exact issue on the latest stable build.
It is the last version
How did you add a KWGT widget to your homescreen?
Here’s the way I add a KWGT widget to my homescreen, you may try this just in case it’s different and perhaps this way would help you.
How to add a KWGT widget to the homescreen
Hi
This doesn’t work all the time,
But thanks anyways.
