Applying the Hue filter appears to work in the editor but as soon as I save, the effect disappears even though the effect is still "applied. "
Here you can see that the effect is not actually being applied. I have also tested this with other objects with an image texture and that issue is also present.
Standalone image objects function with the hue filter correctly.
Very confused and I have no idea why this is happening. (And yes I have tried restarting, it didn’t work)
Update: After waking up this morning the hue effects seemed to work but as soon as I went in and saved, it did the same thing
