My huawei "screen notch" pushes my klck lock screen down. You can see my background behind in on the top of the screen. I do not have this problem with my klwp home screen, which looks great. Thank you :)
Same problem
I have the same problem, I have not been able to use any theme, they look very bad.
Aldo for me, klwp seems to not work properly with the notch on oneplus 6t
Plesde fix
Same for me but on galaxy a40
Hola no puedo poner en mi huawei el tema que cree. Que puede ser?, no encuentro la opción para aplicarlo
