How to remove "service is running" notification?
I notice that a recent update added a persistent “service is running” notification, even though KWGT is not battery optimized on my phone. This causes the notification count to always be 1 more than it should be, reporting 1 notification when there should be none. If I turn off the notifications, I get a message when going into KWGT that the notifications are off and I need to turn them on. How can I fix this so my notification count is accurate?
Go to settings, then notifications. There should be an option that disables the notification. It likely is on force by default or something.
