I'm making Storage Progress Shape
rectangle width (300)
The formula
$100/rm(fstot, int) * rm(fsused)*300/100$
The formula
Create an overlap group with three items
For text object, use these settings
##KUSTOMCLIP##
"clip_version": 1,
"clip_settings": {
"text_expression": "$rm(fsfree, int)/1000$ GB Free",
"text_family": "kfile://org.kustom.widget.provider/fonts/Roboto-Regular.ttf",
"text_size_type": "SINGLE_FONT_HEIGHT",
"text_size": 220.0,
"text_align": "LEFT",
"text_filter": [],
"text_rotate_mode": "NONE"
##KUSTOMCLIP##
If you want to refresh it manually, use this on Touch tab
Kustom Action>> Force RSS/Text/XML update
For the Progress shown shape, use this
##KUSTOMCLIP##
"clip_version": 1,
"clip_cut": [],
"clip_modules": [
"internal_type": "ShapeModule",
"internal_toggles": {
"shape_type": 10,
"shape_width": 0
"internal_formulas": {
"shape_width": "$mu(round,(rm(fstot,int)/1000),2)$GB"
"shape_type": "RECT",
"shape_width": 1460.0,
"shape_height": 60.0,
"shape_corners": 55.0,
"paint_color": "#5CA193ED",
"fx_bitmap_filter": "BW",
"fx_bitmap_blur": 20.0,
"internal_title": "Space Left"
##KUSTOMCLIP##
For the actual Progress bar shape, use this
##KUSTOMCLIP##
"clip_version": 1,
"clip_cut": [],
"clip_modules": [
"internal_type": "ProgressModule",
"progress_progress": 0,
"progress_mode": 0,
"progress_level": 10,
"progress_max": 0,
"style_size": 0
"progress_level": "$rm(fsfree, int)/rm(fstot, int)*100$",
"progress_max": "$rm(fstot, int)$"
"progress_progress": "CUSTOM",
"progress_count": 100.0,
"style_size": 1460.0,
"style_height": 45.0,
"internal_title": "Space Free"
##KUSTOMCLIP##
If done correctly, your progress bar should change width based on how much storage is used.
