Using next line on Text works but on Morphing Text it doesn't.
I use Morphing Text because it has the Spacing option and if I use Text, that element that I made looks so different among the other ones with Spacing.
Can anyone help regarding next line in Morphing Text?
Example Output:
//if WiFi is Connected, shows SSID on first line and connected on next line
SSID:
Status: Connected
//else, just shows disconnected
Status: Disconnected
