Hi,
how can i add a shadow wich is closer than the normal shadow effect to the text in my calendar widget?
Shadow at 0 is not close enough.
Hi,
You can set distance to 0.1, not sure i understood the question well
i added an overlay text with same text in different position and different color.
This will have the same effect.
thx.
No problem, marking as answered then :)
not in my hand ^^
thats your turn.
