I tried the formulas found in the tutorials and other questions but nothing worked. Im using a Progress battery bar, linear, flat progress. Thanks in advance!
Forget it, I figured it out.
Thanks for a great app!
Just as a reference for anyone who might stumble into this:
- Select the color option in the progress bar style
- Turn it into a formula
- Write something like $if(bi(charging), #00FF00, #FF0000)$
This will turn it into red when not charging green when charging.
My code is:
$if(bi(charging) = 0, #000000, 1, #00FF00)$
Green when charging, black discharging.
